Configuring mcuxpressoide.ini file for best performance
2,797 次查看
ptcaos
To get the best performance with MCUXpresso IDE, what are the correct configuration for "mcuxpressoide.ini" file? I have seen some parameters like "Xms" and "Xmx", but I don't know the best way to get a good performance.
Thanks.
9 回复数
2,697 次查看
Pavel_Hernandez
Hello, I asked my partner, and they told me this... I don't recommend changing the parameters from the .ini file... What kind of use case needs to be improved?
Of course, customers can play with those parameters but there's no secret recipe that we're keeping it as a secret with regards to performance...
Pavel
2,687 次查看
ptcaos
Hello @Pavel_Hernandez
I have noticed that when I uninstall some componets, MCUXpresso IDE hangs. At the bar menu bottom, message "Refresh SDK repository" appears, but IDE seems hanged. Because of this I want to know if problem occurs because of a bad "ini" configuration file.
Thanks.
2,665 次查看
Pavel_Hernandez
Hello, did you have the last version of the IDE? some issues are fixed on MCUXpresso v11.9.1 but for that update, the recommendation is to use the red square if you want to stop it.
Pavel
2,654 次查看
ptcaos
Hello @Pavel_Hernandez,
I have installed version 11.9.0 Build 2144. I'm going to try 11.9.1.
Excuse me, but... mmm what is the meaning of your words "but for that update, the recommendation is to use the red square if you want to stop it"?
Thanks.
2,617 次查看
Pavel_Hernandez
Hello, this is the red button.
Pavel
2,707 次查看
ptcaos
Hello @Pavel_Hernandez ,
we use our FRDM-MCXA153 for teaching purposes in our university labs.
Thanks.
2,775 次查看
Pavel_Hernandez
Hello, my name is Pavel, and I will be supporting your case, let me get more information about your questions when I have more details I will contact you.
Pavel
2,731 次查看
ptcaos
ask me what information you need and I will send you.
Thanks.
2,711 次查看
Pavel_Hernandez
Hello, sorry for the late response I will ask my team, could you let us know what your target MCU is for the register.
Pavel
