Configure the IDE to NOT clear the console window when going into debug mode
853件の閲覧回数
jsambrook
Hello -
Hope this is a simple question.
I am using MCUXpresso IDE v11.8.1 [Build 1197] [2023-10-27]. When I go to debug via the Quickstart Panel's Debug link, I watch the Console window in the IDE. Information is printed to the window that I want to read, but the Console window is cleared while target debugging is starting.
How can I configure the Console window to NOT clear unless I elect to clear it manually?  Does the same method work for other windows that clear themselves automatically at different times?
John Sambrook
Common Sense Systems, Inc.
835件の閲覧回数
Hello @jsambrook
Your question is valuable.
After debugging, the log does not clear, you can change view to check as blow:
Hope it helps,
Alice
