Computing of CRC value of the flash memory
3,274件の閲覧回数
zorrotz
I need to test the invariable memory of a Kinetis using the functions provided by the core self-test library for Kinetis CM4 devices.
For other microcontrollers, using CodeWarrior 10.6, the CRC of the invariable memory is calculated in the linking phase and saved in the invariable memory with the application code.
How can this be done with MCUXpresso?
This article describes how to do it for S-Record files: CRC Checksum Generation with ‘SRecord’ Tools for GNU and Eclipse | MCU on Eclipse , but what about .axf ELF/Dwarf files?
Igor Vicente
2,905件の閲覧回数
Hello Pablo,
The MCUXpresso IDE also can generate S-record files, then you can refer to the article you menetioned
to compute CRC.
About how to generate S-record files please refer to : MCUXpresso IDE: S-Record, Intel Hex and Binary Files | MCU on Eclipse
Hope it helps
TIC
2,906件の閲覧回数
Hello Pablo,
to compute CRC.
Hope it helps
TIC
2,905件の閲覧回数
zorrotz
Hello Alice,
Finally I have implemented the flash memory test successfully folowing the post. Know I can debug the application with the information of ELF file.
Igor
