I'm having troubles with the SPIFI and in particular the registers.
According to the manual https://www.nxp.com/docs/en/user-guide/UM10503.pdf we have these registers.
But whe the program is going to write to STAT it fails and gets stuck.
Checking the memory we can see that there are questionmarks instead of data at the STAT location.
Any sugestions of how to fix this?
Solved! Go to Solution.
Hi Alexander Olsson,
TIC
Yes, relocating the application to ram helped! So for anyone who finds this in the future, here is how i did it.
and change the debugger.
I am getting the same exact problem. I am using LPC54016 controller on custom board.
Changed this as recommended,
I am using mcuxpresso 11.5.0,
I have different options.
TIC
