Hi Marco,
You seem to have semihosting enabled for your project, please try disabling this option to the project properties:
When you import a project there is an option on the wizard where you chose to enable or disable this option:
Hope it helps!
Carlos Mendoza
Technical Support Engineer
Hi Marco,
Hope it helps!
Carlos Mendoza
Hi Marco,
Check out this Community document: https://community.nxp.com/docs/DOC-334074?sr=stream
-Anthony
