After install MCUXpresso v11.3.0 (which including J-Link 6.88c), I can not find NXP_iMXRT105x_QSPI.elf under path C:\Program Files (x86)\SEGGER\JLink\Devices\NXP\iMXRT105x.
My custom board uses QSPI flash with rt1050 MCU, how to fix it?
Solved! Go to Solution.
In fact, a 5 second search found this on the Segger support pages:
https://wiki.segger.com/i.MXRT1050
Hi Jing,
I am upgraded from MCUXpresso v11.2.1 to v11.3.0, so I know to modify JLinkDevices.xml for QSPI flash first.
After install MCUXpresso v11.3.0, I can not find file NXP_iMXRT105x_QSPI.elf.
Can you guide me where it is?
No, there isn't such a file.
Jing
Hi Jing,
Does NXP have a solution or workaround to solve it?
It seems segger J-Link driver not including this rt1050 qspi file.
I suspect that this is a file supplied by Segger, as they provide J-Link. Try the Segger forums or support
Hi felix1,
Please refer to this guide. https://mcuoneclipse.com/2019/10/27/using-segger-j-link-with-qspi-flash-on-nxp-i-mx-boards/
Jing
