Want to try USB vcom example on Freedom K64F board.
Import project with newlib_semihost produced this error:
What's going on?
The import continued, and build produced this further error:
c:/nxp/mcuxpressoide_11.1.1_3241/ide/plugins/com.nxp.mcuxpresso.tools.win32_11.1.0.202001081728/tools/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/nxp/mcuxpressoide_11.1.1_3241/ide/plugins/com.nxp.mcuxpresso.tools.win32_11.1.0.202001081728/tools/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+fp/hard\libcr_newlib_semihost.a(syscalls.o): in function `_read':
syscalls.c:(.text._read+0x0): multiple definition of `_read'; ./source/retarget_itm.o:C:\Users\developer\Documents\MCUXpressoIDE_11.1.1_3241\workspace\frdmk64f_dev_cdc_vcom_freertos\Debug/../source/retarget_itm.c:146: first defined here
c:/nxp/mcuxpressoide_11.1.1_3241/ide/plugins/com.nxp.mcuxpresso.tools.win32_11.1.0.202001081728/tools/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/bin/ld.exe: c:/nxp/mcuxpressoide_11.1.1_3241/ide/plugins/com.nxp.mcuxpresso.tools.win32_11.1.0.202001081728/tools/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/lib/thumb/v7e-m+fp/hard\libcr_newlib_semihost.a(syscalls.o): in function `_write':
syscalls.c:(.text._write+0x0): multiple definition of `_write'; ./source/retarget_itm.o:C:\Users\developer\Documents\MCUXpressoIDE_11.1.1_3241\workspace\frdmk64f_dev_cdc_vcom_freertos\Debug/../source/retarget_itm.c:78: first defined here
What's going on?
NXP: please confirm you have reproduced this and filed a bug report
Best Regards, Dave
ie709758@iteso.mx - I am using 11.1.1 with SDK 2.7 on Windows 10.
Simply import the example like this:
1) Choose Freedom K64F no-bluetooth
2) Choose USB CDC VCOM FreeRTOS example
3) Specify newlib (not nano) with semihosting
You will see failure above.
...please confirm you have reproduced this and filed a bug report
Best Regards, Dave
Hi Dave,
I appreciate your patience and additional details. I have not managed to replicate the issue on my side.
To narrow down the problem, Can I suggest you reinstall the IDE and import the example again?
Additional details, Altougth I got the same IDE Error when creating the project, the build succeded
Please let me know your results,
Kind regards, Diego
Seriously? Are you going to tell me to reinstall Windows too? Really now!
Please confirm you've filed bug reports on both the error dialog you have reproduced,
and the build error you did not reproduce.
Best Regards, Dave
Hi Dave,
I hope you are doing well :smileyhappy:
I tried to replicate your issue without success using MCUXpresso v11.1.1 and FRMD-K64F SDK v2.7 and v2.6
Please, help me importing the same SDK example on a different path like c:/projects/ and let me know your results.
Diego.
