Adding Components to MQTT FreeRTOS DemoBreaks demo with SDK LWIP Overwrites
530 次查看
stevenlutz
I have started with the MQTT FreeRTOS Demo on the MCXN947. The demo works fine, however when a component is added, eg, FlexCan. Then the components get updated including LWIP.
LWIP is then broken with an error involving the functions for name reoslution.
In order to move forward and I had to manually copy and include each additional component from another project in order to keep the original LWIP files in place.
Please advise. Thank you
FRDM-MCXN947
1 回复
503 次查看
Harry_Zhang
Hi @stevenlutz
How did you add Flexcan related component?
Will lwip still break when you manually add the relevant code?
Harry
