Not able to download MCUXpresso IDE if account is inactive
Search instead for
No ratings
As a heads-up: several uses reported a problems with downloading the MCUXpresso IDE setup/installer program.
If pressing the 'Download' button, you might come back to the login screen (to log into your NXP user account):
The likely reason for this is that your NXP account needs re-activation. You should see a link to open a SR (Service Request) which you could use.
Otherwise post a comment here so your account can be re-activated.
I hope this helps,
Erich
Comments
Hi Nico,
Your account has been reactivated can you try once more.
Hi Joseph,
Hi jorge_plascencia‌,
Could you please reactivate my account? Thank you.
Hi!
I'm having the same problem, could you please reactivate my account?
Thanks for your time!
Alex
Please re-activate my account.
Thanks.
I am having the same problem. Please re-activate my account. Also, the link to support with the notice of this issue does not work. I just takes me to the NXP home page.
Thanks.
Hi Jakub,
Hi Thomas
Hi Manabu
Hi Alejandro
It works fine, thanks!
Hi Jorge,
Could you please activate my account? Thank you.
I have the same problem:
"You have been redirected to this page because your ID is INACTIVE in Flexera. Please Activate your account to proceed."
Marcelo
My account should be re-activated.
fei xiong
Hello
I also would like my account re-activated
Hi AB
Hi Jesus
Hi Fei
Thanks.
Hi Tomoharu,
your account is active please try now.
Please re-active for me as well, thanks!
BR, Ion
Hi.jorge.
Thanks for your action.
My account has been re-activated.
Please re-active my account.
I have a problem to download MCUXpresso IDE, could you re activate my account please.
    Thank you
My account is blocked too. Could you please activate it?
Br.
Thank you!
It seems that my account also is inactive ... I am experiencing these symptoms.
Could you reactivate my account, please ?
thanks in advance
Hello, my account is also inactive and I can't download MCUXpresso.
Could you please re-activate it ?
Thanks, Stefan
Please reactivate my account. Not able to download MCUExpresso getting the following error message:
If you believe you have reached this page in error, please contact NXP® Technical Support.
Thank you!
Please, activate it for me. Thanks in advance
Can you please re-activate my account?
JF
Hi, NXP technical support,
Please, activate my account.
Thank you very much.
I cannot download MCUXpresso IDE.
could you reactivate my account please.
Thank you
Hello,NXP technical support.
Please, activate my account too.
Thank you
Could you active my account? Thank you!
Hello.
Thank you so mach.But still ,I can't download MCUXpresso.
At this time, the following message will be displayed.
'You have been redirected to this page because your ID is INACTIVE in Flexera. Please Activate your account to proceed. '
Hello.
Hi NXP,
Trying to download MCUXpresso and the download utility doesn't allow me to save the bundle to any folder.
Can someone please re-activate my NXP account?
rgds,
Gary
UPDATE:  I found a work-around.  I was checking the box for the Windows bundle and then clicking the black "Download Selected Files" button.  This sequence would never let me save the file to a folder.  If I just click the actual .EXE file directly, the download works.  This is on Win10 + Google Chrome.
Please reactivate my account, thanks!
Rather than this #))$*#)$*# stupid setup why doens't some one fix the actual problem that 449 of us apparently have?
Please reactivate my account, that should have never been deactivated in the first place.
Version history
Revision #:
1 of 1
Last update:
‎04-02-2017 08:39 AM
Updated by:
