Not able to download MCUXpresso IDE if account is inactive
As a heads-up: several uses reported a problems with downloading the MCUXpresso IDE setup/installer program.
If pressing the 'Download' button, you might come back to the login screen (to log into your NXP user account):
The likely reason for this is that your NXP account needs re-activation. You should see a link to open a SR (Service Request) which you could use.
Otherwise post a comment here so your account can be re-activated.
I hope this helps,
Erich
Comments
Attempting to download MCUXpresso SDK - getting
You have been redirected to this page because your ID is INACTIVE in Flexera. Please Activate your account to proceed.
If you believe you have reached this page in error, please contact NXP® Technical Support.
The Tech support link took me back to the home page. I am able to login and view my account. Please re-activate my account.
HI Hctaws,
Your account has been reactivated, try the link below and see if you do have access:
http://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=MCUXPRESSO
HI Aron,
Hi Enrique,
HI Roman,
Hi Noam,
Hi Allan,
Your account is active and with no issues can you please let me know what is the error you get?
Many thanks, this is now working again - for reference the error was the
same as a few others -
contactNXP^® Technical Support
<https://community.nxp.com/external-link.jspa?url=http%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsps%2Fsite%2Fhomepage.jsp%3Fcode%3DSUPPORTHOME>.
Thanks again for the prompt response.
Mike
Hi, my account appears inactive as well, could please re-activate it?
A.
Hi I have the same problem. Could you please reactivate my account?
Egon
HI Mike,
HI Egon,
Hi Alexander,
My account needs to be reactivated.
Edwin
Hi Edwinrim,
Please, can you reactive my account?
Thanks.
Hi Oscar,
Your account is active and has no issues, can you let me know what is the error you get please
hi,
abviously, this is a internal issue with NXP, I can login with my account, and in account web page, I couldn't seen a account activation link or some what. And, nxp confirmed this is an known issue, why you guys don't try to fix it? make every body here to leave a message for a activation ?
of-course, PLEASE make my account activtied! thanks!
My account needs to be reactivated too.
thanks
Jinlong
My account should be re-activated.
Le
Same problem "your ID is INACTIVE in Flexera"
Could you please re-activate my account.
Thanks in advance,
Jeetendra
Hi Binghoo,
HI Jinlong,
Hi Le Guan,
HI Jeetendra,
Hi ,
Geo
Hi Geo,
I am experiencing problems downloading the S32DS IDE.
Please re-activate my account as well.
Thanks!
HI
I have same account problem downloading MCUXpresso. Please reactivate my account.
Thanks.
Hi Masayoshi,
Plase, reactivate my account as well, thank you
Hi Rastislav,
Please activate my account too.
Thanks in Advance.
Ravindra
Please re-activate me as well,  Thanks!
Hi Ravindra,
Hi Su,
Would you please reactivate my account?
thank you very much in advance.
Hello, I have got the very same issue, would you please re-activate my account as well?
Thanks in advance.
Hi Luca,
Your account is active and with no issues,  can you let me know what is the error message you get please.
Hi Ali,
I can't seem to find your account in the system what is the file that you are trying to download? and what is the error message you get?
Hello Jorge,
I try to download the MCUXPRESSO IDE by pressing on the "download" button as in the following image:
but I get the following error message:
I don"t know what is flexera!!
thank you very much.
Ali
Hi Ali,
can you give me the email address that you are using to access nxp.com please.
Hello Jorge, I use alinassar@gmail.com ( for my personal projects).
However, i have another account at work: anassar@m2s.ca,
Thanks.
Ali
On Wed, Apr 4, 2018, 11:32 AM jorge_plascencia <admin@community.nxp.com>
Hi Ali,
Try now, I have made a change on your account and it should work now.
Please re-activate my account, thanks!
Hello Jorge,
Yes that worked.
Thank you very much for your fast and efficient help.
have a good day.
Ali
Can you please activate my account?
Rob
Hi Rob,
Hi Raymond,
100% helpful (1/1)
Version history
Last update:
‎04-02-2017 08:39 AM
Updated by:
