Not able to download MCUXpresso IDE if account is inactive
As a heads-up: several uses reported a problems with downloading the MCUXpresso IDE setup/installer program.
If pressing the 'Download' button, you might come back to the login screen (to log into your NXP user account):
The likely reason for this is that your NXP account needs re-activation. You should see a link to open a SR (Service Request) which you could use.
Otherwise post a comment here so your account can be re-activated.
I hope this helps,
Erich
Comments
Hi Joost,
Your account is active an with no issues, can you try the link below and see if you do have access:
http://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=MCUXPRESSO
Hi!
Same problem here. Please re-activate for me, or how can I do myself?
Hi Stubee,
Hello Jorge. I try to Download Kinetis SDK and have the same problem, please help me.
My account is inactive, can-you please re-active it ?
Thank you.
My account should be re-activated.
Wojtek
Download doesn't work for me. Please do also reactivate my account.
Hi Edwin,
Hi Boris,
Hi Wojtek,
Lukas,
your account is active and with no issues, can you let e know what is the error message you get?
I’m not able to get to the download link for the MCUXpresso IDE.
When I click on the 'Download' button I arrive at the 'My Account Home Page'. Also I'm not able to find any download to the IDE under the 'Documentation and Tools Updates' section.
Can you provide a direct link to the MCUXpresso IDE?
Hi Lukas,
Try the link below and see if you do have access:
I think that I have the same problem when I try to download "MC-TOOLBOX";
this message appears:
"You have been redirected to this page because your ID is INACTIVE in Flexera. Please Activate your account to proceed. "
How can I activate my account?
Hi Mohamed,
Can you try to access the file once more please, your account has been reactivated.
Please re-activate my account. Thanks in advance!
I get the same error. Could you reactivate my account?
Hi Clemens,
Hi Albert
Need reactivation
Hi r Willson,
your account does not seem to have an issue, what is the error that you are getting.
Hello
I discovered your live chat feature yesterday and Cecelia fixed the problem.
Hello!
I have problems to download MCUXpresso. Can you please re-activate my account?
Armando
Hello.
Can you please reactive my account ?
Thanks.
Hi Armando
Hi Luis
I have the same problem:
"You have been redirected to this page because your ID is INACTIVE in Flexera. Please Activate your account to proceed."
Marcelo
Marcelo
jorgeplascencia
Hi Erich,
I am experiencing problem downloading MCUXpresso IDE. Please re-activate my account please
regards
Viet Anh
Hi Marcelo
Hi Dao
Dear  Erich,
Hi Danjie
please re-activate my account. I'm not able to download MCUXpresso.
The link http://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=MCUXPRESSO, doesn't work either.
Hi Jan
I am experiencing problems downloading the MCUXpresso IDE.
Please re-activate my account as well.
Thanks!
Hi Derek,
Your account seems to be Active with no issues can you let me know what is the error you get?
John
I seem that I have same problem on my account.
Regards.
HI Kiyotaka,
Hi John,
My account should be activated.
Sun
Hi Wei,
please re-active my account, thanks.
cg0
Finally, found here,
My account need to be re-activated.
Thank You
Aron
cg0
If you believe you have reached this page in error, please contact NXP® Technical Support.
I have the same problem.
Please, activate my account
Thank you
Same problem, how do I get my account re-activated???
Roman
Please re-activate me as well,  Thanks!
100% helpful (1/1)
Version history
Last update:
‎04-02-2017 08:39 AM
Updated by:
