Not able to download MCUXpresso IDE if account is inactive
As a heads-up: several uses reported a problems with downloading the MCUXpresso IDE setup/installer program.
If pressing the 'Download' button, you might come back to the login screen (to log into your NXP user account):
The likely reason for this is that your NXP account needs re-activation. You should see a link to open a SR (Service Request) which you could use.
Otherwise post a comment here so your account can be re-activated.
I hope this helps,
Erich
Comments
My account also needs to be reactivated. Thanks!!
Hi Matias,
Your account has been reactivated please the link below to access the files:
http://www.nxp.com/webapp/swlicensing/sso/downloadSoftware.sp?catid=MCUXPRESSO
Hi Marchip,
Hi 进辉苗,
Hi Underwood,
Your account seems to be active with no issues can you elaborate on what is the issue you are facing?
Please re-activate my account please. I'm experiencing problems downloading the IDE.
regards
John
Please Re-activate my account . Thank you
Hi Jonathan Cher,
Hi John,
Your account is active and with no issues can you let me know what is the error you have?
I was unable to download.
I tried again later and it worked. I thought it was reset but didn’t know.
Thank you,
John
My account should be re-activated.
I would like my account to be re-activated please,
Hi Cleev,
Hi Gustavo,
Your account is active and has no issue at all can you let me know what is the error message you see?
You have been redirected to this page because your ID is INACTIVE in Flexera. Please Activate your account to proceed.
If you believe you have reached this page in error, please contact NXP® Technical Support.
Hi Gustavo,
HI
I can't download MCUXpresso i get this message:
Cam you hellp?
Thank you.
Please "re-activate" my account, thanks.
thank you.
Hi Mike,
Hi Walter,
Hi Vitor,
Steven
I have the same issue, could you check my account.
Thanks!
Same problem,
my account should be re-activated.
Alessandro
Hi Steven,
Hi Denis,
Hi Alediano,
Please activate my account. Cant download KSDK. Getting this message
Vivek
Hi Vivek,
Same problem could you please re-activate my account.
Thanks in advance,
Ibrahim
Hi Ibrahim,
Hi Jorge, Could you reactivate my account please?,I have been unable to download LPCExpresso, when I try to download it a message saying "You have been redirected to this page because your ID is INACTIVE in Flexera. Please Activate your account to proceed." appears.
Hi Diego,
I get exactly the same error while trying to download kinetis studio. Could someone please activate my account.
Hi, Enrich
I think my account needs to be re-activated.
Could you fix this problem?
Please rectivate my account for download codewarrior, i have this error:
Stefano
I have the same problem, your ID is INACTIVE in Flexera.
Could you please help me reactive my ID?
Many Thanks.
Same problem "your ID is INACTIVE in Flexera"
Could you please re-activate my account.
Thanks in advance,
Guillaume
Please active my account as well, thanks!
Hi Marko,
Hi SangHoon,
Hi Stefano,
Hi Tao,
Hi Guillaume,
Hi David,
my account needs reactivation. I cannot download kds
Hi Daniel,
Your account is active an with no issues, can you try the link below and see if you do have access:
Please re-active for me as well, thanks!
100% helpful (1/1)
Version history
Last update:
‎04-02-2017 08:39 AM
Updated by:
