hello,I'm using MXCU IDE for the first time.Why didn't I find DSPI module in the peripheral tool?
I'm using mk10dx256xxx10 and the SDK version is 2.2.0.
Solved! Go to Solution.
Hello Qin,
Hope you are doing well.
The DSPI module was not implemented in the peripheral tool. There are drivers available in the SDK that can help you get started in the development of your application.
You can add these drivers to your current project by selecting your project, right click and select SDK Management -> Manage SDK Components -> Drivers and select DSPI.
Please let me know if you have further questions.
Hope it helps!
Sabina
Hello Qin,
Hope it helps!
Sabina
