Does the FreeLink JTAG port (10 pin J34) work for general debugging on the MIMXRT1060-EVK platform? I'm using a J-Link Mini on the 10 pin port, but I get a "J-Link V6.62d Error - MAIN_LogError: Insufficient space in error buffer!" pop-up alert, and then the program jumps to 0xdeadbeee. If I use the LinkServer debug profile, that works as expected so I think the program I'm running - just a simple blinky demo - is not the culprit.
I've used two different J-Link Minis with the same results; I've also checked the cabling to make sure it's correct. The same J-Link Minis work just fine on a K66F board, so I believe they're not the problem. Any insight would be appreciated.
Solved! Go to Solution.
Hello Aaron,
J34 is used to communicate with the on-board LPC4322 MCU. To communicate with i.MX RT device you need to use J21 JTAG connector. For more information I recommend you to check MIMXRT1060 Evaluation Kit Board Hardware User's Guide.
Hope it helps!
Felipe
- We are following threads for 7 weeks after the last post, later replies are ignored.
Hello Aaron,
Hope it helps!
Felipe
