fsl_plu.h: No such file or directory
Search instead for
Using MCUXpresso, trying to build an LPC55S69 or LPC55S28 project with PLU, I get the message:
board/peripherals.h:17:10: fatal error: fsl_plu.h: No such file or directory
What can I do?
Edit:
To reproduce this error,
- create project in MCUXpresso with LPC55xx
- use Pin Tool to configure a few pins for usage as PLU
- build
1 View
Since the Config tools do not add the files required for peripherals like PLU on an existing project.
You can do the following steps.
1) left click on the project
2) go to SDK mangement->manage SDK components
3) Add the driver for PLU and compile.
Please let me know if you have further issues!
Diego
Diego
1 View
Senior Contributor III
Provide more information? You've not given sufficient details for anybody to help you...
