Unable to connect to LPC8N04 over OM40002 Development Board
alexander_maren
I`m not able to debug or flash the LPC8N04 with the OM40002 Development Board. Before I was able to debug and flash the board. I changed nothing, except the code. Now I always get an error: "0 available SWD Devices detected.
Connect a device and try again.". Is there anything I can try? Hope you can help me.
Thank you,
Alexander Marent
Omar_Anguiano
Hello Alexander Marent
I suggest you to verify that your board jumpers (p7,p8) are connected as this image shows:
If this is not applicable I suggest to follow the Section 4 of the User Manual for LPC8N04 Development Board
Let me know if this is helpful
Omar
alexander_maren
the jumpers were applied correctly. I tried to use a J-Link debug probe and everything worked fine. So the J-Link solved my problem.
Thank you,
Alexander Marent
