ULinkPro MCUXpress
Showing results forย
Search instead forย
Did you mean:ย
ULinkPro MCUXpress
naasikhendricks
Hi I would like to use my UlinkPro to do tracing with Mcuxpress. It is a Eclipse based toolchain and i don't want to mess around too much with current xpress settings.
Kind regards
jingpan
Hi Naasik,
It's not sure. You can try. If the ulinkpro firmware is CMSIS DAP, MCUXpresso can support it. You may ask ARM for help.
Jig
naasikhendricks
jingpan
Hi Naasik,
Ulink2 has a CMSIS-DAP firmware. It can be recognized by MCUXpresso. But I'm not sure if Ulink pro also has. You can try. If it has, you can see in MCUXpresso
Jing
naasikhendricks
Hi thank you for the reply. ARM promotes coreinsight which is CMSIS DAP and GNU.
ยตVision Debugger
I really want to trace but the JTrace is crazy expensive and If i can use it in one environment then i can use it in all the environments.
Kind regards
