Seeing more cases of "Error: Read timed out LinkServer has been terminated and will be restarted" when trying to debug download my project
2,000 次查看
fastwalker2
Hi All,
Originally, debug downloading to my LPC43S67 board was very reliable.  I'm using MCUExpresso IDE v10.1.1 [Build 606]  on Windows 10.  Lately, when trying to debug download my project I'm getting this error below more than 50% of the time.  I've tried power-cycling the board and restating the IDE but that doesn't seem to help.  How do I solve the problem?
Error in final launch sequence
LinkServer has been terminated and will be restarted.
Please restart your debug session.
If the problem recurs, please power cycle your debug probe and restart MCUXpresso IDE.
标记 (1)
1,596 次查看
Carlos_Mendoza
Hi Sean,
Maybe the problem is the application that is being loaded,  if you load the periph_blinky example does the same behavior is present? You could try booting the part in ISP mode to see is the this solves the connection  problem.
You can find more information on this link:
https://community.nxp.com/thread/389112
Hope it helps!
Carlos Mendoza
Technical Support Engineer
