I inherited a LPCXpresso project which runs on a LPC1769 board. I tried to move it to MCUXpresso and was able to get it to compile after a couple errors. Now when I try to download it to the board it downloads however it doesn't run, any suggestions on what I might be missing?
Hello TomLaVecchia,
Which project? You can send your original project to me , I help to check it on my side.
Alice
At this time, I cannot send it to you. I'm trying to get approval to send it.
My next question is, should I have been able do just import the LPCXpresso project into MCUXpresso or did I need to start a new project under MCUXpresso and then just copy the code into the folder?
Hello TomLaVecchia,
Usually, we can directly import and open it with MCUXpresso IDE.
You can also create a private case in salesforce and send your project.: https://support.nxp.com/s/
Choose LPC space, and also can add this thread linker in description, I will help you to test it on my side.
Alice
I can't send the entire project including code,
Is there another way we can work on this? Can I just send a configuration file or something?
Hello TomLaVecchia,
Without project, it hard find the issue, I saw you have create new case on salesforce, you can attach some compile error .
Alice
