Migrating a project from LPCXpresso to MCUXpresso
3,385 次查看
TomLaVecchia
I inherited a LPCXpresso project which runs on a LPC1769 board. I tried to move it to MCUXpresso and was able to get it to compile after a couple errors. Now when I try to download it to the board it downloads however it doesn't run, any suggestions on what I might be missing?
5 回复数
3,381 次查看
Hello TomLaVecchia,
Which project? You can send your original project to me ,  I help to check it on my side.
Alice
3,369 次查看
TomLaVecchia
At this time, I cannot send it to you. I'm trying to get approval to send it.
My next question is, should I have been able do just import the LPCXpresso project into MCUXpresso or did I need to start a new project under MCUXpresso and then just copy the code into the folder?
标记 (1)
3,354 次查看
Hello TomLaVecchia,
Usually, we can directly import and open it with MCUXpresso IDE.
You can also create a private case in salesforce and send your project.: https://support.nxp.com/s/
Choose LPC space, and also can add this thread linker in description, I will help you to test it on my side.
Alice
3,342 次查看
TomLaVecchia
I can't send the entire project including code,
Is there another way we can work on this? Can I just send a configuration file or something?
标记 (1)
3,323 次查看
Hello TomLaVecchia,
Without project, it hard find the issue, I saw you have create new case on salesforce, you can attach some compile error .
Alice
