McuxPresso Binary file
Search instead for
claudiobrunelli
I have just created a new test proget with the xpresso ide. In the attached file ther's the corresponding binary file and a little screenshot of it.
Does anyone to explain me why I find in this file the information that I lighted ? Is this correct to find this kind of information in the binary file ? Is there any setting to make to avoid it ?
Thanks in advance.
Claudio
ErichS
Senior Contributor III
Hi @claudiobrunelli ,
Yes. It is because you have asserts enabled in your project.
Yes. Because you are using asserts the way it is implemented in the SDK
Yes, disable asserts with the NDEBUG setting. See https://mcuoneclipse.com/2016/03/09/dealing-with-code-size-in-kinetis-sdk-v2-x-projects/
PS: There is a nice hex editor plugin in Eclipse too. Have a look at https://mcuoneclipse.com/2012/04/02/5-best-eclipse-plugins-4-ehep/
I hope this helps,
Erich
ErichS
I hope this helps,
Erich
claudiobrunelli
Hi ErichS
As usual, your tips & tricks are very very precious.
Claudio
ErichS
thanks you :-).
To add to the answer: there reasons for the strings are the asserts which use things like __FILE__ and __LINE__ for the printf() messages: they get stored in FLASH.
Erich
