i am running the flexcan_interupt example program from the FRDM-KW36 Dev. Board on the MKW36A512VFP4.
The example runs fine with a baud rate of 125k. But with all other standard baud rates like 100k, 250k, 500k or 1000k. I can't get the example to work. With a baud rate of 125k I can see the Send Message clear on the Scope but with all the other I can't get a clear Message to work. Is there something I have to change at the Clock or bit time timings?
The strange thing I don't understand is that the example is configured standard with 1000k baud rate.
Every advice is highly appreciated.
Lukas
Solved! Go to Solution.
Could you please help me checking this thread and confirm if this helps you ?
[KW36] FlexCAN Bit Timing Parameters Setup
I believe that you can find there the information you are looking for.
Estephania
Estephania
