MCUxpresso can't find my FRDM-K64F (no OpenSDA option)
brettutesch
I purchased a new FRDM-K64F but MCUxpresso is unable to find it when plugged in via USB.  I've updated the bootloader in which now it says "MAINTENANCE" when in bootloader mode.  I then updated the additional file (I don't understand what this "additional" file is but the website said to update it) in which it now mounts as DAPLINK.  MCUxpresso is still unable to find this board.
Any suggestions as to what I'm doing wrong?
FYI - I trying to get to a point in which I program the MCUxpresso examples via the OpenSDA.
danielchen
Hi Brett:
I encountered this issue before. I updated the firmware application then it works.
OpenSDA Serial and Debug Adapter | NXP
lpcxpresso_supp
The typical reason for this is that on Windows you need to install the "mbed serial port driver" from
MCUXpresso IDE Support
brettutesch
I installed the mbed serial port driver.  MCUXpresso still cannot find the FRDM-K64F board.
danielchen
Hi Brett:
brettutesch
Hi Daniel,
Seggar JLink V2 board specific firmwares worked.  I actually tried them all.  Only the Seggar worked.  Thank you for your help.
Brett
