Hello sir,
I deleted the sdk files to import them again, into the MCU Xpresso IDE. However it has been showing this error "Unable to import, as file already exists.", when dragging and dropping the sdk file folder. I deleted the main file multiple times, and finally uninstalled the MCU IDE and installed it again but it is still showing the same error. Please guide asap.
Hi Manibha:
Could you clarify what IDE you are using? I would recommend you use version 10.2.1
For the exist issue, I guess maybe you have installed this package before.
Please open the default location to check it, for example, in my PC, the default is
C:\Users\[XXYY]\mcuxpresso\01\SDKPackages
You can delete it and try it again
