I am developing a project using mcuxpresso when debugging my code always appears an error message (No source available for "g_pfnVectors () at 0x0"). I tried several ways to solve this problem but so far unsuccessful! Thank you for your attention!
1,782 次查看
rosimarsilvaper
1,400 次查看
Carlos_Mendoza
Hi Rosimar,
You can find more information about this thread on the following link:
https://community.nxp.com/message/925994
As mentioned on that post, preventing this from happening is actually very hard, as it depends on all sorts of configuration and timings between the PC, the debug probe and the target. And many users won't actually see it in their particular setup.
This doesn't actually stop debugging. Just close that particular edit box, and potentially click on the "main" in stack frame displayed in the Debug View at the top of the screen, and you should then be back in business.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
