How to turn off the automatic '*' in C++ multi-line comments?
chadgraham
Contributor V
When adding lines as part of a C++ multi-line comment in MCUXpresso, which preference setting turns off the '*' for additional lines?
ErichStyger
Senior Contributor V
You can have your own code templates here:
chadgraham
Contributor V
I tried changing the C++ templates, but I am still getting the asterisks.  The files comment I use for my file header (confirmed works), but the others do not seem to control the comment asterisk.  Is there one in particular that I should be focused on?
Alexis_A
Hello Chad,
As you mention, the asterisk didn't dissapear. I also tried some other methods but also didn't work so I think this can't be done.
Alexis Andalon
