How to place array in specific bank and align it
2,207 次查看
michaeldkfowler
 I am trying to place an array in a specific memory bank and align it. I tried the following and it didn't work:
__BSS(RAM) SDK_ALIGN(static ULONG usb_cached_memory[USBX_MEMORY_SIZE / sizeof(ULONG)], 64);
标记 (1)
2,103 次查看
michaeldkfowler
This worked:
__attribute__ ((section(".bss.$NCACHE_REGION"), aligned(8)))static ULONG usb_memory[USBX_MEMORY_SIZE / sizeof(ULONG)];
4 回复数
2,104 次查看
michaeldkfowler
This worked:
2,184 次查看
Hello @michaeldkfowler
Do you use MCUXpresso IDE? If yes, please refer to <MCUXpresso IDE User Guide> ->
19.13 Placement of specific code/data Items .
Alice
2,178 次查看
michaeldkfowler
The guide does not answer my question
2,110 次查看
So how do you think I can help you?
How about send a simple project that includes your requirements,  I help you change.
BTW, which MCU do you used?
Alice
