How to flash .bin images of IMXRT1050/LPC55S69 from LINUX PC?
sreedevi_mohan
We have successfully flashed .bin images of rt1050 from a windows pc and please find the attached doc for the steps.
   1. How we can flash the same .bin file from a linux pc?
   2. What should be the steps for flashing?
Sabina_Bruce
The steps to drag and drop the file should be the same. You would need to confirm how the imxrt or the lpc55s69 is enumarating on your computer when you plug it in.
Could you please confirm how it looks when plugged in then I can check to see if you need additional steps.
Sabina
sreedevi_mohan
HI,
It's worked in case of imxrt1050. But we didn't get any partition mounted on windows /linux pc while connecting lpc55s69. How we can flash the .bin files to lpc55s69 from linux/windows pc ?
