How to create standalone project using MCUExpresso SDK for keil IDE ?
1,084 次查看
karthikpoojary
I want to know how can I create standalone project for Keil IDE using MCUExpesso SDK. I am new to the MCU Exoresso SDK when I was using KSDK using Project Generator Iwa s able to generate the standalone projects easily,do you have any similar application for the new SDK ?
I am using MKV11Z128 MCU
标记 (2)
842 次查看
Hello Karthik Poojary,
Yes, you can use the MCUXpresso Config Tools generate a standalone KSDK project for Keil ,
please refer to the below steps:
- Download the SDK package for your chip ,  https://mcuxpresso.nxp.com/en/select
  choose  Keil MDK  IDE ,
-  Download and install MCUXpresso Config Tools :
MCUXpresso Config Tools|NXP
refer to the "MCUXpressoConfigTools_User_Manual"->Chapter 6 Project Cloner create your project .
Hope it helps
TIC
842 次查看
marek-trmac
Hi Karthik Poojary,
you can also download any SDK example directly from MCUXpresso SDK builder web site. Just in your dashboard click on the download icon for any SDK package and select `Download Standalone Example Project`. This is standalone example, that can be build without SDK package.
Marek
Marek
