How to backup data of RTC module MKE04?
1,490 次查看
chunghusttdh
When I set date and time, the RTC module running normally, but I reset MCU, date and time also reset :smileysad:. Let me ask if I have something missing?? Thank you!
标记 (1)
2 回复数
1,437 次查看
miduo
You did not mention that what your RTC configuration. Actually MKE04 has no backup power domain and requires the processor to remain powered in a very low leakage state, usually using a low power 32Khz oscillator rather than crystal. That is to say you need to use a low leakage mode instead of power off to keep the processor powered that will keep the RTC data.
1,437 次查看
chunghusttdh
help me :smileysad:
