I'm using MCUexpresso 10.2 with SDK 2.4
When you create a project, it asks all kinds of things including what drivers you want in it, which is fine.
The problem I'm having is that I need to add some drivers into the project. I can't figure out how to do that at this point.
How do I edit the list of drivers and middleware that was originally used to generate the project as the project evolves?
In KDS and PEX this is trivial to do.....
已解决! 转到解答。
Hi Randy,
there is a button to add/remove SDK drivers/components. See Eclipse MCUXpresso IDE 10.1 with integrated MCUXpresso Configuration Tools | MCU on Eclipse and search for "add/remove components".
I hope this helps,
Erich
Hi Randy,
I hope this helps,
Erich
