How do you recover after a NAK from I2C_RTOS_Transfer?
ソリューションへジャンプ
989件の閲覧回数
tfont
I'm using MCUXpresso V10.2.1 and the V2.4.1 SDK for the FRDM-KL27Z.
I can't seem to re-use the I2C handle after getting a kStatus_I2C_Nak when calling I2C_RTOS_Transfer.  Each access after the NAK gives me an kStatus_I2C_ArbitrationLost.  I've tried calling I2C_RTOS_Init again and I've also tried calling I2C_RTOS_Deinit then I2C_RTOS_Init but no matter what, I always get an Arbitration Lost.
Is there some other way to reset the peripheral?  What's the recommended way to recover from a NAK or an Arbitration Loss?
823件の閲覧回数
jingpan
Hi Anthony,
It seems you have multimaster on i2c bus. I2C_RTOS_Deinit does not clear S.ARBL. You can use I2C_CheckAndClearError(...) to clear it. This function is in fsl_i2c.c.
Jing
824件の閲覧回数
jingpan
Hi Anthony,
Jing
