Does MCUXpresso Config Tools v.4.0 support MK60DN512xxx10 ?
mikhailmaizelis
I'm trying to use the MCUXpresso Config Tools v.4.0 to configure peripherals on the MK60DN512VLL10 MCU. Both "Pins" and "Clocks" tools work great but the "Peripherals" tool reports that the MCU is not supported. This MCU is listed as supported by the MCUXpresso IDE. I built an SDK for the MCU, created various projects, compiled and debugged them and everything worked. So what's wrong with the "Peripherals" tool for MK60DN512VLL10 ?
ZhangJennie
Hi Mikhail.
There is no problem on your side.
You use MK60DN512VLL10. For this chip, MCUXpresso IDE,SDK,Pin Config Tool, Clock Config Tool are available.
But Peripheral Config Tool is not available yet.
Jennie Zhang
