Did any one success run FlexCan Interrupt demo in SDK2.0 for MK22F120?
changfuzhao
I am try to running flexcan interrupt (two board) demo in sdk2.0 for MK22FN120, but I never got success,
and more please let me know what is difference between MK22FN1M0Axxx12 and MK22FN1M0xxx12?
jorge_a_vazquez
Hi Changfu Zhao
We recommend to use the latest SDK drivers in order to avoid any possible bug on older versions. I could run the flexcan_interrupt driver example code for twrk21f120m following the readme file.
About your other question, please check the following link:
https://community.nxp.com/docs/DOC-102548
Hope this could help you.
Best Regards
Jorge Alcala
changfuzhao
thanks for your reply,
I used SDK2.2 now, and my MCU is MK22FN1M0VLH12,
I port the demo from twrk21f120m to my board, and run it talk to my CAN bus device by 250k, but, I didn't  success by many times. but I can use Process Expert generate code and success communication to my device.
I just think may be the bit rate calculation in SDK has some thing wrong.
