I uninstalled MCUXpresso 10.2.0 and installed MCUXpresso 10.2.1. I opened a project and click ConfigTools the ConfigTools windows shows "no processor selected". The ConfigTools for pins, clocks and peripherals has the similar error message. I think it works with the previous version.
Solved! Go to Solution.
Hi Tom.
You need well connect internet when first using config tool. MCUXpresso needs download some data to cache for first usage.
You can also refer this article of how to use config tools offline
How to Use MCUXpresso Config Tools on Offline Computer
Jennie Zhang
Hi Tom.
Jennie Zhang
Hi Jennie,
Thanks! It works.
Tom
You are welcome.
Jennie.
