Can FRDM-K64F MCUXpresso IDE use Zephyr RTOS
1,998 次查看
nicholas_yameen
I have used Zephyr RTOS on the FRDM-K64F board mainly using the command line.  Is it possible to use MCUXpresso IDE to create a Zephyr project? I am using Ubuntu 16.04.
Thank you,
Nick
标记 (2)
1 回复
1,732 次查看
maureen
Hi Nick,
You can generate an Eclipse project from cmake. This step needs to happen from the command line, but after that you can edit, build, and debug from Eclipse.
Here are some relevant links:
Application Development Primer — Zephyr Project Documentation
Zephyr Project using Eclipse
Maureen
