CM7 IMXRT containerize dev ops?? I was wanting to turn our dev environment into a container.
1,141 次查看
anthonygarza
We are currently using mcu expresso. I would like to have the developers be able to just download a docker file that has all of the needed development tools in it and be able to develop from within a container.
1. Should we migrate to vs code since it has built in container tools? If so is there a good tutorial to migrate an mcuexpresso project to vs code? Be able to build and debug from within vs code?
2. Or should VNC into the container?
Any thoughts or ideas on this?
1 回复
1,125 次查看
anthonygarza
Bump
