Is it possible to setup different build profiles with different base addresses?
Hi @mspenard603 ,
not sure what you exactly mean, but if it is about changing the linker file and using different addresses e.g. for a bootloader application, you can use the NXP MCUXpresso IDE and FreeMarker scripts for this: https://mcuoneclipse.com/2019/10/06/linking-bootloader-applications-with-eclipse-and-freemarker-scri...
I hope this helps,
Erich
I simply want to have the base address change in MCU Settings based on the build profile:
It is not possible to change anything about the MCU based on the build profile, including the address map.
