Bad unit displayed in flexcan peripherals of configTools
durand_e
With FRDM-KW36 EVK:
I have a baudrate of 1Mhz
Bit quantum should be baudrate / 10 so 100 ns and not 100 µs.
See screenshoot below
Same for bit time
You can also change "buad rate" by "baud rate"
Tags (2)
marek_neuzil
Hello Eric,
Thank you for reporting of this issue. We have fixed the calculation of the Time Quantum, Bit time and the typo in the FlexCAN component.
You can use the attached hot fix package to fix the issue in your local data (see the readme.txt file of this patch for details).
Sabina_Bruce
Hello Eric,
Hope you are doing well.
Thank you for taking the time to provide this feedback. I will pass this on to our IDE team focused in the config tool, to make the appropriate corrections!
Sabina
