unable to create MCUXpresso New configuration based on existing keil uVision project
2,480 次查看
kabraham_abin
when selecting tool chain, I found that MCUXpresso config tool was not supporting uVision 4 projects. the error shown was "no tool chain project detected". To fix this i have migrated the uVision 4 project to uVision5 project. But a new error is showing up which states "No processor detected for import in MDK uVision project". What could be the possible reason and how this can be fixed?  Note: I have verified that the target processor is defined in the MDK uVision project file. #MCUXPresso
2 回复数
2,155 次查看
kabraham_abin
I found the issue that the series which I was using doesn't supported by the config tool.
2,465 次查看
Petr_H
I'm sorry, but Config Tools only support version 5 of the Keil uVision projects.
Could you please share with us the project or some sample project that we could use for reproducing the problem ?
Petr Hradsky
Config Tools Team
