The xsd for the latest Config Tools for iMX is again not available on http://mcuxpresso.nxp.com/XSD/mex_configuration_1.9.xsd. It was the same with the 1.8 version (it was fixed some time after we notified NXP support of the problem). We need the xsd to process mex files using our internal tool. Can you please make this file available?
Thanks.
解決済! 解決策の投稿を見る。
Hi Michael,
thank you for reporting this issue. It has been fixed now.
Libor
The same is true for every version released after 1.9:
https://mcuxpresso.nxp.com/XSD/mex_configuration_1.10.xsd
https://mcuxpresso.nxp.com/XSD/mex_configuration_1.11.xsd
https://mcuxpresso.nxp.com/XSD/mex_configuration_1.12.xsd
https://mcuxpresso.nxp.com/XSD/mex_configuration_1.13.xsd
None are available. Can you please add to the team's instructions to upload the xsd file to the mcuexpresso server whenever they release a new version of the Config Tool?
For now, please make sure all the above files are available. Thanks!
The new XSDs are available, but there has been a change in the name of XSD file after the V9 so the URLs that you anticipated will not work. You need to use the following URLs:
https://mcuxpresso.nxp.com/XSD/mex_configuration_10.xsd
https://mcuxpresso.nxp.com/XSD/mex_configuration_11.xsd
https://mcuxpresso.nxp.com/XSD/mex_configuration_12.xsd
https://mcuxpresso.nxp.com/XSD/mex_configuration_13.xsd
best regards
Petr Hradsky
Config Tools Team
Great, thank you!
