When I try to configure the pins in the config tool for the jn5189dk6_zigbee_ed_rx_on_bm demo project I get an error:
Issue: Processor core 'core0' detected in MCUXpresso_IDE project does not match with currently selected `cm4`
Level: Error
Type: Tool problem
Tool: McuConfiguration
Origin: jn5189dk6_zigbee_ed_rx_off_bm
Resource: Processor Core
Information: -
Any help would be appreciated.
This has solved the issues, thanks a lot
Hi Jacinto,
I analysed the problem and it's caused by incorrect identification of the core in the SDK package. To workaround it, please:
1. In downloaded JN5189 SDK package zip archive, go to the JN5189_manifest_v3_4.xml and JN5189_manifest_v3_5.xml files and change the following line:
<core id="core0_JN5189" name="core0" fpu="false" type="cm4"/>
to:
<core id="core0_JN5189" name="cm4" fpu="false" type="cm4"/>
2. Install the modified SDK package to the MCUXpresso IDE
Let me know if this will resolve the problem.
Lukas
I reproduced the issue. I will check it with config tool team. Will keep you informed
Jun Zhang
Thanks, I'll be waiting.
