Unable to use CMSIS GPIO driver
已解决
跳至解决方案
3,520 次查看
WaSt
i would like to use the Config tool to do the initial setup and bringup of my custom board.
I want to use the CMSIS drivers for I2C, SPI, UART and GPIO.
Unfortunately MCUXpresso Config Tool only allows CMSIS drivers for I2C, SPI and UART.
In the Peripheral Tool section you can choose the universal GPIO peripheral driver, but it uses the gpio adapter driver (fsl_gpio_adapter.c/.h) and not the CMSIS driver.
Therefore the generated RTE_Device.h does not include the GPIO stuff, which is included by the GPIO CMSIS driver. One could manually add the #defines to the RTE_Device.h, but adapting generated files is never a good idea and should not be needed.
So as I see it, it is not possible to use/generate Code for using the CMSIS GPIO drivers with the MCUXpresso Config Tool.
Is this correct or am I missing something?
Versions:
Config Tool: v25.3
Peripherals: v15
Stefan
标记 (4)
1 解答
3,438 次查看
EdwinHz
Hi @WaSt,
I have corroborated this behavior and indeed ConfigTools does not currently support cmsis GPIO for this MCU.
That said, the driver is still existent, so you can import the cmsis gpio to your project by right clicking the project folder, selecting SDK Management > Manage SDK Components, and selecting gpio_cmsis under cmsis drivers. The implementation of this driver would have to be manual.
BR,
Edwin.
在原帖中查看解决方案
4 回复数
3,493 次查看
EdwinHz
Hi @WaSt,
Could you please specify what MCU are you using in order to further investigate this issue?
3,479 次查看
WaSt
Sure, I am using the MCXA153.
标记 (1)
3,439 次查看
EdwinHz
Hi @WaSt,
BR,
Edwin.
3,362 次查看
WaSt
MCXA153
%3CLINGO-SUB%20id%3D%22lingo-sub-2150872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A0%E6%B3%95%E4%BD%BF%E7%94%A8%20CMSIS%20GPIO%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150872%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E4%BD%BF%E7%94%A8%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E6%9D%A5%E5%88%9D%E5%A7%8B%E8%AE%BE%E7%BD%AE%E5%92%8C%E5%90%AF%E5%8A%A8%E6%88%91%E7%9A%84%E8%87%AA%E5%AE%9A%E4%B9%89%E6%9D%BF%E3%80%82%3CBR%20%2F%3E%E6%88%91%E6%83%B3%E5%B0%86%20CMSIS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%94%A8%E4%BA%8E%20I2C%E3%80%81SPI%E3%80%81UART%20%E5%92%8C%20GPIO%E3%80%82%3C%2FP%3E%3CP%3E%E9%81%97%E6%86%BE%E7%9A%84%E6%98%AF%EF%BC%8CMCUXpresso%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E5%8F%AA%E6%94%AF%E6%8C%81%20I2C%E3%80%81SPI%20%E5%92%8C%20UART%20%E7%9A%84%20CMSIS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%A4%96%E8%AE%BE%E5%B7%A5%E5%85%B7%E9%83%A8%E5%88%86%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E9%80%9A%E7%94%A8%20GPIO%20%E5%A4%96%E8%AE%BE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E4%BD%86%E5%AE%83%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20gpio%20%E9%80%82%E9%85%8D%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88fsl_gpio_adapter.c%2F.h%EF%BC%89%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20CMSIS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E7%94%9F%E6%88%90%E7%9A%84%20RTE_Device.h%20%E5%B9%B6%E4%B8%8D%E5%8C%85%E5%90%AB%20GPIO%20%E5%86%85%E5%AE%B9%EF%BC%8CGPIO%20CMSIS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%8C%85%E5%90%AB%E4%BA%86%E8%BF%99%E4%BA%9B%E5%86%85%E5%AE%B9%E3%80%82%E6%88%91%E4%BB%AC%E5%8F%AF%E4%BB%A5%E6%89%8B%E5%8A%A8%E5%B0%86%20%23defines%20%E6%B7%BB%E5%8A%A0%E5%88%B0%20RTE_Device.h%EF%BC%8C%E4%BD%86%E4%BF%AE%E6%94%B9%E7%94%9F%E6%88%90%E7%9A%84%E6%96%87%E4%BB%B6%E7%BB%9D%E4%B8%8D%E6%98%AF%E4%B8%80%E4%B8%AA%E5%A5%BD%E4%B8%BB%E6%84%8F%EF%BC%8C%E4%B9%9F%E4%B8%8D%E9%9C%80%E8%A6%81%E3%80%82%3C%2FP%3E%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%E6%88%91%E7%9C%8B%E6%9D%A5%EF%BC%8C%E4%BD%BF%E7%94%A8%20MCUXpresso%20%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E4%BD%BF%E7%94%A8%2F%E7%94%9F%E6%88%90%E7%94%A8%E4%BA%8E%20CMSIS%20GPIO%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E4%BB%A3%E7%A0%81%E6%98%AF%E4%B8%8D%E5%8F%AF%E8%83%BD%E7%9A%84%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%EF%BC%8C%E8%BF%98%E6%98%AF%E6%88%91%E9%81%97%E6%BC%8F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%3CP%3E%E7%89%88%E6%9C%AC%EF%BC%9A%3CBR%20%2F%3E%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%EF%BC%9Av25.3%3CBR%20%2F%3E%E5%A4%96%E5%9B%B4%E8%AE%BE%E5%A4%87%EF%BC%9Av15%3C%2FP%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EStefan%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2152974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20use%20CMSIS%20GPIO%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2152974%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230047%22%20target%3D%22_blank%22%3E%40WaSt%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E8%AF%81%E5%AE%9E%E4%BA%86%E8%BF%99%E4%B8%80%E8%A1%8C%E4%B8%BA%EF%BC%8CConfigTools%20%E7%9B%AE%E5%89%8D%E7%A1%AE%E5%AE%9E%E4%B8%8D%E6%94%AF%E6%8C%81%E8%AF%A5%20MCU%20%E7%9A%84%20cmsis%20GPIO%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%B9%9F%E5%B0%B1%E6%98%AF%E8%AF%B4%EF%BC%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%8D%E7%84%B6%E5%AD%98%E5%9C%A8%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BD%A0%E5%8F%AF%E4%BB%A5%E9%80%9A%E8%BF%87%E5%8F%B3%E9%94%AE%E5%8D%95%E5%87%BB%E9%A1%B9%E7%9B%AE%E6%96%87%E4%BB%B6%E5%A4%B9%EF%BC%8C%E9%80%89%E6%8B%A9%20SDK%20%E7%AE%A1%E7%90%86%20%26gt%3B%20%E7%AE%A1%E7%90%86%20SDK%20%E5%85%83%E5%99%A8%E4%BB%B6%EF%BC%8C%E7%84%B6%E5%90%8E%E5%9C%A8%20cmsis%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8B%E9%80%89%E6%8B%A9%20gpio_cmsis%20%E6%9D%A5%E5%B0%86%20cmsis%20gpio%20%E5%AF%BC%E5%85%A5%E5%88%B0%E4%BD%A0%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%B8%AD%E3%80%82%E8%AF%A5%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%BF%85%E9%A1%BB%E6%89%8B%E5%8A%A8%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20use%20CMSIS%20GPIO%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151469%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%BD%93%E7%84%B6%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20MCXA153%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2151165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Unable%20to%20use%20CMSIS%20GPIO%20driver%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2151165%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F230047%22%20target%3D%22_blank%22%3E%40WaSt%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E8%AF%B4%E6%98%8E%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E7%A7%8D%20MCU%EF%BC%8C%E4%BB%A5%E4%BE%BF%E8%BF%9B%E4%B8%80%E6%AD%A5%E8%B0%83%E6%9F%A5%E6%AD%A4%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
