MCUExpresso Config tool and RT1064 SEMC
3,852 次查看
randyhermes
If there a way to configure the RT1064 SEMC SRAM mode in the MCUExpresso Config Tool?
When you select the SEMC it only allows the SDRAM interface to be configured.
According to the processor reference manual region 6 of the SEMC is used for the SRAM interface.
I would like to use this feature to interface to an external FPGA.
Randy
3,824 次查看
randyhermes
Hi Adrian,
Thanks for letting me know.  Are there any plans to expand SEMC configuration support in future versions?
Randy
3,825 次查看
randyhermes
Hi Adrian,
Randy
3,817 次查看
addiyi
Hi Randy,
We plan to support all SEMC interfaces in the next releases.
Adrian
3,835 次查看
addiyi
Hi Randy,
Currently only SEMC/SDRAM is supported in MCUXpresso Config Tools.
Adrian
