K32L2B21:How to complete to call static constructors
3,333 次查看
rodger_an
For C++ project, how to complete the constructors function call in start up file?
3,274 次查看
ErichStyger
Specialist I
Hi @rodger_an ,
not sure if I understood your question. But you might have a look at my blog article on a related subject: https://mcuoneclipse.com/2020/07/11/from-c-to-c-converting-eclipse-c-projekts/
See the section about the C++ startup code.
The thing is that you can call the constructor initialization for global objects in the startup code, but this depends on the standard library used.
I hope this helps,
Erich
4 回复数
3,275 次查看
ErichStyger
Specialist I
Hi @rodger_an ,
I hope this helps,
Erich
3,250 次查看
rodger_an
Thank you! ErichS.
Now I know the Cpp start up file . And know how to generate a ld script for C++ project.
3,284 次查看
jingpan
Hi @rodger_an
You can create a function which call the constructor in main.c. Then call this function in startup file. This function must be called after everything initialized.
Jing
3,248 次查看
rodger_an
Hi JINGPAN,
Thanks for your direction.
