Is config tool v8 support for MCIMX7D7DVM10SD?
Search instead for
Hi, I'd like to use MCUXpresso Configuration Tools to set up my SOC Colibri iMX7, But i found in latest version v8 only supports MCIMX7U3xxxxx, MCIMX7U5xxxxx these two chips(also seei.MX 7ULP), and my chip is i.MX 7Dual, So that I have a question, is it possible to use config tool for i.MX 7Dual? if it possible which i select, if not, is there any other tools to help?
Thank you very much.
Unfortunately MCUXpresso Config Tools does not support i.MX7D.
Sorry for the inconvenience.
