Hello Patrice,
I guess you did not save the Config Tools configuration (*.mex file) when this problem occurs. Still, could you please attach here the *.mex file and spcify what exactly you entered as the identifier? This could accelerate the reproducibility of the issue.
Thank you,
Libor
Hi Patrice,
thank you for reporting this issue. Attached you can find patch fixing the problem in MCUXpresso Config Tools v6 and MCUXpresso IDE 11.0.x. You can install it using following steps:
1. In MCUXpresso Config Tools go to File > Data Manager, in MCUXpresso IDE go to ConfigTools > Data Manager
2. Choose Import... and browse to the attached archive
3. Select processors for which you want to apply the patch
4. Restart MCUXpresso Config Tools or MCUXpresso IDE
The fix will be included in next version of MCUXpresso IDE and Config Tools.
Lukas
