For KE18F processors is there Processor Expert in KDS or Peripheral tab of ConfigTools in MCUxpresso?
已解决
跳至解决方案
3,329 次查看
onurdemirel
I am using TWR-KE18F board. I looked for Kinetis Design Studio and MCUxpresso IDEs but I couldn't find how to generate startup or initialization codes. Is there any other way to obtain these codes?
If no way to obtain these codes from manufacturer due to not supporting, I am curious about the reason behind this? Is this procedure not applicable for the processor or is the processor too old for this application. If the reason is processor-based, I can change the processor before starting my project.
Last thing I think about this issue is; can I use any other processor that have similar pin-outs and necessary hardware and also supported by the manufacturer for this code generation issue.
Thanks in advance,
Onur
标记 (1)
1 解答
2,785 次查看
You can both use KDS and MCUXpresso IDE to develop the TWR-KE18 board.
There is  MCUXpresso SDK MCUXpresso SDK|NXP  , it not only includes the startup or initialization codes,
but also drivers  and lost demos .
So first  you need to download SDK package for TWR-KE18 from https://mcuxpresso.nxp.com/en/select   ,
after downlaod , there is a quick start "Getting Started with MCUXpresso SDK.pdf" under SDK package ,
it describe how to use and run demo on KDS, MUCxpresso . Also the "MCUXpresso_IDE_User_Guide.pdf"
says how to use SDK on MCUXpresso IDE.
Hope it helps
TIC
在原帖中查看解决方案
3 回复数
2,785 次查看
onurdemirel
Hi Alice,
I am partially satisfied with your answer. Thanks for it. However I am still wondering why we can't use the Peripheral part of ConfigTool. It would be very easy and time-efficient by adjusting peripheral properties.
Onur
2,785 次查看
Hello Onur,
As to the MCUXpresso Config Tool is a  new software ,  it only support parts of NXP chips,
the others will continue be released .
About the supported update , you can follow this thread :
https://community.nxp.com/docs/DOC-333073
Hope it helps
Alice
2,786 次查看
Hope it helps
TIC
