Error in Config Tools for FlexCAN
已解决
跳至解决方案
3,459 次查看
stefano-quantic
In: Config Tools | Peripherals | Peripheral drivers (device specific) | FLEXCAN | Flexcan general configuration | FlexCAN configuration
there is a setting named "Self Reception" (the 14th settings of this block; it's a checkbox).
It should be renamed "Disable Self Reception", since its value determines the value of flexcan_config_t.disableSelfReception in the generate code (in peripherals.c), which in turn determines the setting for FlexCAN's bit MCR[SRXDIS].
The current name suggests the exact opposite of what it does, so it's very confusing.
This is for a project using iMXRT1176.
1 解答
3,391 次查看
marek_neuzil
Thank you for reporting the issue. You are right that the name of the setting is confusing and should be fixed.
I have already created a ticket to fix the issue in the next release of MCUXpresso Config Tools.
Marek Neuzil
在原帖中查看解决方案
1 回复
3,392 次查看
marek_neuzil
Marek Neuzil
