Hello!
I'm new to mcuxpresso config tool.
May I know how to change the LANGUAGE from "Chinese" to "ENGLISH"?
I did select "ENGLISH" during installing.
Thanks for your help!
Hi Chance Huang, from the documentation:
1.2 Tools localization
The Tools support English and Chinese languages, based on your locale settings.
To manually set the locale, add the following parameter to the command line:
tools.exe -nl zh
It is possible to set the locale in the tools.ini file by adding the following line:
-Duser.language=zh
The supported languages are:
• en - English
• zh – Chinese
Marek
Dear Marek,
Thanks a lot for your help!
I did it, and worked.
By the way, we choose "MK40DX256VLL7", which is 100-pin PQFP, for our design.
However, I only found "MK40DX256VLQ10 - LQFP 144 package" from MCUexpresso.
Is the MCUexpresso right tool for me? or what am I wrong?
Appreciate your help!!
Hi again,
I found in this document: https://community.nxp.com/docs/DOC-333073 that MK40DX256VLL7 is not planned in MCUXpresso IDE and MCUXpresso Config Tools.
Marek
Dear Marek,
Got it!
If I'd like to configure the pin of "MK40DX256VLL7/ 100-pin PQFP", any suggestion tool?
Thanks!!
Hi Chance,
You can use KDS with processor expert. it supports MK40DX256VLL7
Jennie Zhang
Dear Jennie,
Thanks for your information!!
Chance
welcome!
Jennie Zhang
